Hello Guest it is April 25, 2024, 08:08:44 PM
Author Topic: How to hook-up a manual THC low budget  (Read 3690 times)
« on: February 22, 2015, 11:39:29 AM »
I would like to hook-up two push button switches for my torch, one push button for up and one for down. I don't have any room in my input breakout board. I know I need another board and a second parallel port. Not so good for electrical, can some one help me on this?
Ratpackjavascript:void(0);
Re: How to hook-up a manual THC low budget
« Reply #1 on: May 23, 2015, 03:02:27 PM »
If you are looking for external jog buttons;
You can use a usb device to send up and down button to mach3 with modbus. And just create a brain file for use the usb device's IO s as an z++/z-- jog input...
But If you want to use this inputs as a thc. There is a delay around 100ms in modbus with brains. You need a plugin to discount the delays.
« Last Edit: May 23, 2015, 03:07:29 PM by furkanyilmaz11 »
« Reply #2 on: May 25, 2015, 05:57:35 PM »
Set up the THC function as emulated with Hotkeys.  If needed remote use a simple usb keypad that uses the same hotkeys as youset up for THC control.
