Ron,
Nice for the NFS Turn wizard and thanks for the reply.
BUT............
Some wizards ( written by other users ) are based on current configuration and don't check the modes that your are
configured for, so one must be carefull when using them.
I think that is partialy the case for the Simple Threading wizard. It checks to see if you are in diameter or radius mode,but, generates code based on input.
So if one does all inputs in Metric, but, the machine is configured for inches then one would need to add
a G21 to the program and G20 at the end. Also one should make a comment line of what units the code is based on.
For my new lathe screen set all used wizards (other than NFS) are modified and a check is made for say diameter / radius mode and adjustment made including other changes.
