Hello Guest it is April 25, 2024, 12:46:18 PM
Author Topic: Spindle WarmUp Wizard  (Read 5752 times)
Offline Bodini
  •  216 216
« on: February 17, 2015, 04:13:36 PM »
Here is a wizard to make the code to warm up a spindle.  Place this mcs file in the Wizards folder for M4 and use it from the Wizards pull-down menu.
« Last Edit: February 17, 2015, 04:16:32 PM by Bodini »
Offline dude1
  •  1,253 1,253
Re: Spindle WarmUp Wizard
« Reply #1 on: February 17, 2015, 05:59:53 PM »
cool
« Reply #2 on: June 02, 2015, 02:47:03 PM »
Slightly corrected version. With the original, I always was starting at 1000rpm. Not quite what we're looking for when our router/spindle's slowest speed is 3000. So I corrected the While loop to start at the requested startRPM and then increment by  the step increment over the time specified. This version goes one increment over the requested max rpm
Offline Klaus
  •  42 42
« Reply #3 on: July 17, 2018, 05:54:48 AM »
Is it important to warm up the spindle?
If, yes for how long time? and do you just let it run at a certain sped or....?
