Hello Guest it is April 26, 2024, 05:06:38 PM
Author Topic: Scanything  (Read 32481 times)
Scanything
« on: February 14, 2015, 07:15:17 AM »
I found this program on the Sheetcam website today and I'm wondering if anyone here has used it.
I have managed to get Scanything to work but I can't save any file without purchasing the licence. Before I do that I'd be keen to hear of anyones experience with it.
I have been looking for a template tracing program for awhile now. I have tried and tried to get the copycat addon in Mach3 to work properly but it doesn't. That was a waste of money.
Re: Scanything
« Reply #1 on: February 14, 2015, 09:02:22 AM »
Re: Scanything
« Reply #2 on: February 14, 2015, 03:15:09 PM »
You can count on anything that LES at SheetCam produces, WORKS. And he WILL support it.
Re: Scanything
« Reply #3 on: February 14, 2015, 07:38:53 PM »
Not sure what our doing.
Copycat works....read the manual!
Re: Scanything
« Reply #4 on: February 14, 2015, 08:30:43 PM »
Rich, I appreciate the work that you put into the manual and I have read it SO many times thinking I'm doing something wrong.
The problem that I wrote about in this topic is what I get every time.
http://www.machsupport.com/forum/index.php/topic,27456.0.html
Here's a small file I did of a rectangular plate with 2x 10mm holes in the lower corners.
When I load that file into Mach3 it wants to cut 2x huge holes that are not even close to where they should be.
This is a little off topic but it's the problem I'm having with Copycat that made me look for other solutions.
« Last Edit: February 14, 2015, 08:37:06 PM by ozymax »
Re: Scanything
« Reply #5 on: February 15, 2015, 07:43:14 AM »
ozymax,
I use CopyCat infrequently. So I would need to spend time looking at both Mach and Copycat to get a better perspective of the problem.
I use it mostly to get the profiles of objects for both the lathe and the mill by backplotting the gcode.
As far as the manual goes, well, I wrote it because there was no instructions on how to use it and accomplished  the writing by hacking away at it.
Understand your frustration.....what more can i say.
Maybe Ron will read this post and can look into it since it's a NFS program.
Re: Scanything
« Reply #6 on: February 15, 2015, 08:08:09 AM »
I started a conversation with Mach support yesterday, so maybe they can solve the problem.
Would you be so kind as to load that text file into Mach3 and post a screen shot of what you get?
I'd appreciate the help.
Re: Scanything
« Reply #7 on: February 15, 2015, 08:20:49 AM »
ozymax,
Using your posted code file :
Same code used in Mach, but with different IJ MODE configurations in Mach.
See attached pic.
Isn't that what you want ? :)
Re: Scanything
« Reply #8 on: February 15, 2015, 08:43:54 AM »
The top picture shows what I was wanting, but I just get the bottom picture.
So how or what do I need to do?
What is IJ MODE and where does it come into it?
Re: Scanything
« Reply #9 on: February 15, 2015, 09:09:18 AM »
Mach3 is configurable for the way one works.
You can change how Mach will interpret the G code.
Config>General Configuration...and in the approx middle of the screen you will see where you can select
the Distance and IJ modes.
