Hello Guest it is April 26, 2024, 12:50:32 AM
Author Topic: CNC 6040z-4s The Z-Axis Page up and Page down Control keys are reveresed?  (Read 5637 times)
I am setting up a CNC 6040z-4s mill and the controls for the Z-axis stepper motor are reversed.  I went to the config->system hotkeys and selected page up for the Z++ and page down for the Z-- and they are reversed from what they should be.  I can reverse the hot keys assignments by selecting page down for Z++ and page up for Z-- but I am wondering if that is the correct way to correct this.  Is there some other method that this should be corrected.  Thank you.
Re: CNC 6040z-4s The Z-Axis Page up and Page down Control keys are reveresed?
« Reply #1 on: February 13, 2015, 08:28:51 PM »
Page Up for Z++ would be correct for the key.
If the Z goes DOWN when you hit this key, you can reverse the direction of travel buy changing the Active State of the Dir. pin.
« Reply #2 on: February 16, 2015, 12:01:58 PM »
Thank you, changing the active state of the directional pin did the trick.
