Hello Guest it is March 28, 2024, 06:09:24 AM
Author Topic: Can plugin handle input signal @ speed of 100Hz?  (Read 2508 times)
« on: February 12, 2015, 02:12:35 PM »
I have an application where i need to move x axis 1mm forward as soon as input signal is triggered. Approx speed of that input signal will be 100 Hz. It will not be exact same and will vary +10% to -10%. But I need to move x axis exactly same number as input signal. I had tried some macro, it worked at very slow speed but as I increased speed it lost synchronization.
So is it possible to work at such high speed via plugin or brain? Because somewhere while searching for solution, I read that mach3 can only update @ 10Hz.
