Hello Guest it is April 25, 2024, 07:12:13 PM
Author Topic: Zero radius arc Block=N135 G3 X1.0719 Y2.5396?  (Read 3863 times)
« on: February 07, 2015, 03:23:18 PM »
I purchased the licensed LazyCam, and I'm trying to test it out for making a little speaker baffle with a driver recess.
I imported a DXF file, and everything looks pretty good in LazyCam.
But when I post the file and open it in Mach3, I'm getting the error above ("Zero radius arc Block=N135 G3 X1.0719 Y2.5396").
I've posted the LazyCam file here, could someone tell me what I'm doing wrong?
Also, when I try to post, LazyCam says "No Mach3 found running."  I've checked both my Mach3 and LazyCam license files, they're in place.  And in those apps, I've tried Help/About and it shows the apps are licensed to me.  I wonder if this is related to Mach3 not liking the file.  I suppose I should have posted something more simple, didn't think of that.
Re: Zero radius arc Block=N135 G3 X1.0719 Y2.5396?
« Reply #1 on: February 07, 2015, 08:16:17 PM »
Have a look at my reply to your other post.
