I am newbie into the CNC world. I use shapeoko as my CNC machine. I am using my CNC machine to mill speaker cutouts. I use skectchup , cambam , mach3 combination for all my cutout's
I have started of with making certain cutout's tough most of them have been successful I am facing problems with the cutouts which have circle's. The work piece is rectangle 9" X 6"inch 18mm plywood which shows perfectly on cambam touching the X,Y Axis lines. When I export the G-Code into Mach3 and check the circle and the greyed out workpiece the circle seems to be showing up on the upper right corner rather than the center of the workpiece. I have tried other workpieces which do no have circles but simple pocketing jobs and the workpiece and the tool path shows up perfectly. I do not know if this is a cambam export issue or mach3 related problem.
Any help on this will be highly appreciated.
