Hello Guest it is April 25, 2024, 11:04:00 AM
Author Topic: G-Code scaling program, mm to Inches and back  (Read 103025 times)
Offline Graham Waterworth
  •  2,673 2,673
  • Yorkshire Dales, England
« on: April 08, 2007, 07:56:04 PM »
Hi All,
here is a small .exe program for converting G-Code from mm to Inches and Inches to mm, it will also scale to any size you require, with in reason.
The program needs no installing, just double click to run it.
Click 'input file' to select the source file
Click 'output file' and enter a new file name, you can't read and write to the same file name.
Select conversion options.
Click convert.
That's all there is to it.
Try it and see if it works for you.
There is a later version of this program higher within this thread that has no limit to the number of lines of g-code it will convert, this version has a line limit of 32000.
Link to Later version :- http://www.machsupport.com/forum/index.php/topic,2893.msg39920.html#msg39920
Regards
Graham.
« Last Edit: June 20, 2010, 04:21:27 PM by Graham Waterworth »
Re: G-Code scaling program, mm to Inches and back
« Reply #1 on: April 08, 2007, 08:12:58 PM »
Hats off to Graham for such a nice contribution. Some of you folks will find this very useful if your code generating is limited to Imperial or metric. Men like Graham are one of the main reasons this forum is so nice.
Thanks Graham
ynneb
« Reply #2 on: April 08, 2007, 11:06:28 PM »
Thanks Graham, You're more than just a pretty face.
« Reply #3 on: April 09, 2007, 03:30:46 AM »
Archive is dead. Winrar don't open it. I me or something else?
TIA
GB
ynneb
« Reply #4 on: April 09, 2007, 03:55:03 AM »
Try downloading it again. Seems to work fine for me.
« Reply #5 on: April 09, 2007, 04:06:06 PM »
Thank's Benny - the .exe file work now.
GB
« Reply #6 on: September 25, 2007, 09:41:02 PM »
why does it try to install TurboTax ItsDecductible 2006 when i go to open this thing?
  •  2,673 2,673
« Reply #7 on: September 26, 2007, 04:44:21 AM »
No idea, it worked for 450+ other people.
Graham.
« Reply #8 on: September 26, 2007, 10:29:42 AM »
hmm, thanks for app anyway, will try to get it working today...
  •  2,673 2,673
« Reply #9 on: September 26, 2007, 11:49:53 AM »
I have just downloaded both version and they both work fine here.
Graham.
