Hi Guys,
I am nearly finished with my CNC-Mill and now got A Problem.
I'm using a pokeys 57E with
Firmware 3.1.17
and Mach3 Version R3.043.066
I was able to get everything started and Jogging and Homing works fine.
My X-Axis counts positive when jogging from left to right,
My Y-Axis counts positiv when jogging from front to back and
My Z-Axis counts negative when jogging from up to down.
When I send G0 X100 everything is perfect.
BUT, when I do the same with Y and Z axis, they want to go in the wrong direction.
As I'm using Pokeys I'm not allowed to change anything in Ports and Pins and MotorOutput.
I had to check reverse to Y and Z axis under Config...Motor Home/Softlimits to get the right counting wehn jogging.
I had to check Home neg. for Z axis. (see attached pic)
My scale right to the X Y Z axis says +1
Why is Mach 3 Jogging and counting everything correctly but moves the Y and Z axis in the opposite direction then g gode should move them?
Where is my fault?
Thanks for your help,
cheers Lukas
