Hello Guest it is April 19, 2024, 08:09:08 PM
Author Topic: A Galil Mach 3 communication problem I need help with.  (Read 14481 times)
Re: A Galil Mach 3 communication problem I need help with.
« Reply #10 on: September 12, 2018, 02:53:53 PM »
Mach4 does not support the DMC 17xx or 18xx
It the other way around, those model Galill's do not have the plugin required to work with Mach4. Have you asked Gallil
if they intend on releasing a Mach4 plugin?
Your suggestion to just use Mach 4 is great, except for the expense involved
$200 for Mach4, how much is you machine worth?....or your existing Galill?
Have you thought about LinuxCNC....its free!
« Reply #11 on: September 12, 2018, 04:32:49 PM »
From what I understand Galil does not create the Mach3 plugins, they are done by NewFangled Solutions if they get done at all, and there is no intention of creating a plugin for any Galil controllers except the Ethernet ones. At this point I can get by with Mach3.
