Hello Guest it is March 04, 2026, 12:42:46 AM
Author Topic: need help converting a probing script made for linuxcnc  (Read 7329 times)
Offline ronny
  •  17 17
« on: January 15, 2015, 04:49:43 PM »
i have this script that i want to use with a laser probe, i am trying to scan a kite board, usually with linux cnc, you open this script as a gcode but with mach3, it doesnt like it.
the script generate a text file that i can open in a open source program call boardcad.
here is the script if someone can help me:
g21
f1000
(#1=0)       (x start)
(#2=3190)      (x end)
#3=20      (nr of segments; 20)
#4=[[#2-#1]/#3]   (x step)
#5=-268.5      (y center)
#6=10      (nr of points; 10)
#7=10      (y step)
#8=-36     (z safe)
#9=10      (z probe)
#10=0      (current x)
#11=0      (current y)
#12=0      (current z)
#13=0      (previous z)
#14=0      (step size y)
#15=-100   (y safe)
#16=-100   (z probe outline)
#18=1110   (x-value between support / approximately center of board)
O100 sub (subroutine find apex for cross section scan)
   g38.2 z#9
   o101 while [0 lt #5070]
      g38.4 y#15 f5000
      #10=#5061
      #11=#5062
      #12=#5063
      g38.3 z[#12-50] f1000
   o101 endwhile
O100 endsub
(search for tail and nose)
g0 z#8 a45
g0 x#18 y#5
g38.2 z#9
o6 while [0 lt #5070]
   g38.4 x0 f5000
   #10=#5061
   #11=#5062
   #12=#5063
o6 endwhile
g0 x[#10-10]
g38.2 x#18
#1=[#10+5]
#17=#5063    (start y, used for outline)
g0 z#8
g0 x#18 y#5
g38.2 z#9
o7 while [0 lt #5070]
   g38.4 x3500 f5000
   #10=#5061
   #11=#5062
   #12=#5063
o7 endwhile
g0 x[#10+10]
g38.2 x#18
#2=[#10-5]
#10=#1
g0 z#8
g0 x#1 y#5
(PROBEOPEN bottom_rocker.txt)
g38.2 z#9
g0 z#8
g0 x[#10 + 20]
g38.2 z#9
o1 while [#10 lt [#2-#4/4]]
   #10=[#10+#4]
   g0 z#8
   g0 x#10
   g38.2 z#9
o1 endwhile
g0 z#8
g0 x[#10 - 20]
g38.2 z#9
(PROBECLOSE)
g0 z#8
g0 x#1 y#15
g0 z#17
#10=#1
(PROBEOPEN outline.txt)
g38.2 y#5
g0 y#15
g0 x[#10 + 20]
g38.2 y#5
o2 while [#10 lt [#2-#4/4]]
   g38.4 z#8   (probe for apex)
   #17=#5063
   #10=[#10+#4]
   g0 y#15
   o8 if [#5061 GT #18]
      g0 x#10 z[#17-80]
   o8 else
      g0 x#10 z[#17-40]
   o8 endif
   g38.2 y#5   (probe for outline)
o2 endwhile
g0 y#15
g0 x[#10 - 20]
g38.2 y#5
(PROBECLOSE)
g0 z#8
g0 x[#1+304.8] y#5
M1       (wait if user wants to prepare board)
O100 call
g0 y[#5062+10]
g38.2 y#5
g0 z#8
#10=#5061
#11=#5062
#12=#5063
#7=[[#11-#5]/#6]   (y step)
(PROBEOPEN bottomrail1.txt)
g38.2 z#9
o23 while [ #5062 gt [#11-#7]]
   g0 z#8
   g0 y[#5062 - 3]
   g38.2 z#9
o23 endwhile
o3 while [ [#5+#7/2] lt #11]
   #11=[#11-#7]
   g0 z#8
   g0 y#11
   g38.2 z#9
o3 endwhile
(PROBECLOSE)
g0 z#8
g0 x[[#1+#2]/2] y#5
O100 call
g0 y[#5062+10]
g38.2 y#5
g0 z#8
#10=#5061
#11=#5062
#12=#5063
(PROBEOPEN bottomrail2.txt)
g38.2 z#9
o24 while [ #5062 gt [#11-#7]]
   g0 z#8
   g0 y[#5062 - 3]
   g38.2 z#9
o24 endwhile
o4 while [ [#5+#7/2] lt #11]
   #11=[#11-#7]
   g0 z#8
   g0 y#11
   g38.2 z#9
o4 endwhile
(PROBECLOSE)
g0 z#8
g0 x[#2-304.8] y#5
O100 call
g0 y[#5062+10]
g38.2 y#5
g0 z#8
#10=#5061
#11=#5062
#12=#5063
(PROBEOPEN bottomrail3.txt)
g38.2 z#9
o25 while [ #5062 gt [#11-#7]]
   g0 z#8
   g0 y[#5062 - 3]
   g38.2 z#9
o25 endwhile
o5 while [ [#5+#7/2] lt #11]
   #11=[#11-#7]
   g0 z#8
   g0 y#11
   g38.2 z#9
o5 endwhile
(PROBECLOSE)
g0 z#8
(finished scanning bottom)
#8=400      (z safe)
g0 z#8
g0 x#2 y#5   (place probe over nose)
M0      (wait for user to turn board)
g0 x#1 y#5   (place probe over tail)
M0      (wait for user to place board)
M1      (optionally wait for fine tuning)
(scanning deck)
#10=#1
g0 z#8
g0 x#1 y#5
(PROBEOPEN deck_rocker.txt)
g38.2 z#9
g0 z#8
g0 x[#10 + 20]
g38.2 z#9
o11 while [#10 lt [#2-#4/4]]
   #10=[#10+#4]
   g0 z#8
   g0 x#10
   g38.2 z#9
o11 endwhile
g0 z#8
g0 x[#10 - 20]
g38.2 z#9
(PROBECLOSE)
g0 z#8
g0 x[#1+304.8] y#5
O100 call
g0 y[#5062+10]
g38.2 y#5
g0 z#8
#10=#5061
#11=#5062
#12=#5063
(PROBEOPEN deckrail1.txt)
g38.2 z#9
o33 while [ #5062 gt [#11-#7]]
   g0 z#8
   g0 y[#5062 - 3]
   g38.2 z#9
o33 endwhile
o13 while [ [#5+#7/2] lt #11]
   #11=[#11-#7]
   g0 z#8
   g0 y#11
   g38.2 z#9
o13 endwhile
(PROBECLOSE)
g0 z#8
g0 x[[#1+#2]/2] y#5
O100 call
g0 y[#5062+10]
g38.2 y#5
g0 z#8
#10=#5061
#11=#5062
#12=#5063
(PROBEOPEN deckrail2.txt)
g38.2 z#9
o34 while [ #5062 gt [#11-#7]]
   g0 z#8
   g0 y[#5062 - 3]
   g38.2 z#9
o34 endwhile
o14 while [ [#5+#7/2] lt #11]
   #11=[#11-#7]
   g0 z#8
   g0 y#11
   g38.2 z#9
o14 endwhile
(PROBECLOSE)
g0 z#8
g0 x[#2-304.8] y#5
O100 call
g0 y[#5062+10]
g38.2 y#5
g0 z#8
#10=#5061
#11=#5062
#12=#5063
(PROBEOPEN deckrail3.txt)
g38.2 z#9
o35 while [ #5062 gt [#11-#7]]
   g0 z#8
   g0 y[#5062 - 3]
   g38.2 z#9
o35 endwhile
o15 while [ [#5+#7/2] lt #11]
   #11=[#11-#7]
   g0 z#8
   g0 y#11
   g38.2 z#9
o15 endwhile
(PROBECLOSE)
g0 z#8
M2
Re: need help converting a probing script made for linuxcnc
« Reply #1 on: January 15, 2015, 05:23:39 PM »
You cannot convert it directly. EMC code and MACh3 code different dramatically in some areas. This is ONE of those areas.
Mach3 cannot do conditional Gcode which is WHAT you have.
Just a thought, (;-) TP
Offline ronny
  •  17 17
« Reply #2 on: January 15, 2015, 09:16:39 PM »
what are my option do the same thing?
« Reply #3 on: January 16, 2015, 10:50:10 AM »
You MIGHT be able to rewrite it as a Mach3 MACRO but it wont be pretty and it wont be fast.
