Hello Guest it is April 26, 2024, 03:56:44 AM
Author Topic: Mill wizard  (Read 5740 times)
Mill wizard
« on: January 13, 2015, 02:34:42 PM »
 new setup of mill wizard . When I load a gcode file from mill wizard to Mach3. The machine moves as it should but the mach3 screen dro does not match the amount traveled. This causes my z axis to trip limit switch.   5 inches of travel will read .5 inches on mach3 screen this is a guess of actual ratio between actual travel and screen readout. Any suggestions?  Mach3 running on windows 7.  Thanks Ed cova
Re: Mill wizard
« Reply #1 on: January 13, 2015, 03:37:04 PM »
Make sure your native units are not set to mm's.
Re: Mill wizard
« Reply #2 on: January 13, 2015, 03:54:39 PM »
Have you tested the calibration of your machine? When you command a Z move does the machine really move that amount?
The wizard simply generates gode moves, it cannot effect how mach executes that code.
Re: Mill wizard
« Reply #3 on: January 13, 2015, 07:29:08 PM »
As long as I don't load g code from mill wizard. All moves are accurate one inch travel on axis = one inch on Mach3 screen dro.
Re: Mill wizard
« Reply #4 on: January 13, 2015, 09:59:54 PM »
Unless you are mixing units and programming the wizard in mm on a machine setup in inches it is simply not possible for the wizard to make a longer move. The wizard simply writes gcode. Use the MDI bar and enter a move, like G1 z1 and see if Z moves exactly 1 inch.
Re: Mill wizard
« Reply #5 on: January 14, 2015, 09:00:12 AM »
Did you check the Native Units?
If you configure your machine to accurately move in inches, but the Native units are set to mm's, then any g-code without a G20 will move the correct distance in inches, but if there's a G20, it will move 25.4x more than it's supposed to, which is what you said in your first post.
