Hello Guest it is April 19, 2024, 12:46:53 AM
Author Topic: Homing Limit Warning Message  (Read 5914 times)
« on: January 05, 2015, 11:18:14 AM »
Using ESS Ethernet, Gecko 540 with Mach v0.62... when I use the ESS homing/limits I get a "Exceeded Soft Limit" warning on Mach after homing. Happens on X,Y & Z axis. Played with the ESS homing settings but still get the exceeded limits warning. If I uncheck "Use this configuration" on the ESS homing config page (reverting back to Mach homing routine) no warning message.
The ESS homing works ok except for the warning message.
Any ideas?
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Homing Limit Warning Message
« Reply #1 on: January 05, 2015, 03:13:50 PM »
Without looking at your Mach 3 profile my guess would be that the ESS is exceeding the soft limits when it is trying to home, probably because it is going a little too far in the -Axis direction. I always set the soft limits to something like -0.1" or so. That way when homing you can go past zero a little ways to find the home sensor.
Happy machining , Jeff Birt
