OK I have the upgraded boards.
It now has the ESS Smothstepper eathernet board and a C11GS break out board.
So here is the new problem
I get the motors to respond but, under ports and pins if I have no check mark under ether Dir low active, or step low active, the right arrow will work in the correct direction and the left does not. Then if I check Step low active the same arrow key will go the other direction and the left arrow key still does nothing. This is the same on all axis. Can you please give me an idea.
Thanks.
