Hello
Guest
it is
April 25, 2024, 12:34:06 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
License Installing problem
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: License Installing problem (Read 18089 times)
teroma
1
Re: License Installing problem
Reply #10 on:
June 21, 2016, 03:15:23 AM »
Having same problem as reported by cliffh in 2007 - will load on one computer and not another. Must be a simple answer to this problem, surely?
Logged
jroberson
29
Reply #11 on:
June 25, 2016, 08:39:15 PM »
After receiving 20855 license for Mach3, copied to Mach3 directory OK, but still shows as demo, no name, and limited gcode? See attached license.
I appreciate the help.
Edit - License file removed for security reasons - Tweakie.
Last Edit: June 26, 2016, 01:34:41 AM by Tweakie.CNC
Logged
Tweakie.CNC
9,199
Super Kitty
Reply #12 on:
June 26, 2016, 01:44:40 AM »
Unzip the license file that was sent to you.
Open the folder mach3.
Open the folder JOHN……….
Copy the file Mach1Lic.dat into your C: Mach3 folder.
On restarting Mach3 you will have Licensed To: John………... and the demo restrictions removed.
Logged
jroberson
29
Reply #13 on:
June 26, 2016, 08:43:04 PM »
Half way there... there was no folder named John........ So I pasted Mach1Lic.dat into Mach3 Directory. It ran all gcodes without limits, but when I
looked at license under help, the name was not mine. It was MaoAA Dtonas?
Logged
Tweakie.CNC
9,199
Super Kitty
Reply #14 on:
June 27, 2016, 02:13:47 AM »
The license file you previously posted here was the correct file, the one you have just installed on your PC is
not
the correct file.
I have tested your license file and it is working correctly and displaying your name.
Go back to your original email from Licensing to get the correct zip file, unzip it and copy that Mach1Lic.dat into your Mach3 folder.
Logged
jroberson
29
Reply #15 on:
June 27, 2016, 07:14:57 AM »
Thanks again, I'll give it a try today.
Logged
jroberson
29
Reply #16 on:
June 28, 2016, 09:26:10 PM »
Thanks Tweakie, that solved that problem.
Logged
Tweakie.CNC
9,199
Super Kitty
Reply #17 on:
June 29, 2016, 01:24:33 AM »
I am pleased that you have it sorted.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
