Hello Guest it is April 23, 2024, 10:13:33 PM
Author Topic: Updated Soigeneris documentation  (Read 4020 times)
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« on: December 28, 2014, 12:09:57 PM »
Happy New Year!
I was helping a customer this past week with a ESS configuration issue and I initially forgot about the special spindle speed control settings for the SmoothStepper. So, I quickly added this information and the information about the new homing/limits settings to my documentation. All of this information is on the Warp9 forum but is hard to find if you don't know what your looking for.
This was done quickly so as to get the information out there. I'll clean up the formatting in the days to come. If you see anything that is incorrect or is confusing please let me know:
USB: http://www.soigeneris.com/Document/Warp9/Installing_and_Configuring_the_SmoothStepper.pdf
Ethernet: http://www.soigeneris.com/Document/Warp9/Installing_and_Configuring_the_Ethernet_SmoothStepper.pdf
Happy machining , Jeff Birt
Re: Updated Soigeneris documentation
« Reply #1 on: January 03, 2015, 02:30:20 PM »
Using ESS Ethernet, Gecko 540 with Mach v0.62... when I use the ESS homing/limits I get a "Exceeded Soft Limit" warning on Mach after homing. Happens on X,Y & Z axis. Played with the ESS homing settings but still get the exceeded limits warning. If I uncheck "Use this configuration" on the ESS homing config page (reverting back to Mach homing routine) no warning message.
The ESS homing works ok except for the warning message.
Any ideas?
