Hello Guest it is April 26, 2024, 01:12:41 AM
Author Topic: mach3 not loading gcode  (Read 2084 times)
« on: December 26, 2014, 10:22:04 PM »
I went to use my vcarve file in mach3 and when I tried to load the file, it didn't load anything. I tried to pull an old file that has worked in the past, and again nothing. I get a little green dot where the path picture usually is, but nothing else. Also no pathway shows in the runlines. Any help is appreciated.  Thanks in advance
  •  9,199 9,199
Re: mach3 not loading gcode
« Reply #1 on: December 27, 2014, 02:04:43 AM »
Go into the Diagnostics screen and check that you have not inadvertently turned off the Toolpath Display (lower left of screen).
