Hello Guest it is April 16, 2024, 02:14:48 AM
Author Topic: Manually add a Brains folder?  (Read 14520 times)
« on: December 26, 2014, 03:39:41 PM »
Seems that I got no Brains folder in my Mach3 folder. Is it possible to add that later, or do I have to reinstall the program?
Regards / Jimmy
Offline dude1
  •  1,253 1,253
Re: Manually add a Brains folder?
« Reply #1 on: December 26, 2014, 04:28:51 PM »
yes just make a folder
« Reply #2 on: December 26, 2014, 05:50:23 PM »
I tried that but Mach3 don't load brains that's in that folder.
Offline dude1
  •  1,253 1,253
« Reply #3 on: December 26, 2014, 07:45:14 PM »
did you label it Brains.
if that did not work reload M3 the Brains folder should of all ready been there
« Reply #4 on: December 27, 2014, 09:29:25 AM »
Hi! My installation/Mach3-folder just got this folders:
GCode
LCamSamples
Shapes
So I made a "Brains" folder, but non of the brains files in that folder show up in the "Brain Control". And I have restarted my computer several times. The only Brain file that I can see in the Brain Control is "ModIOMPG.brn", but that one is not on my computer harddrive.
« Reply #5 on: December 27, 2014, 09:40:03 AM »
What version of Mach3 is this?
Where did you install it to?
Sounds like your looking at the wrong folder.
« Reply #6 on: December 27, 2014, 10:58:23 AM »
Yes Gerry, you are right. For some reason I got two Mach3 folders, and when I searched for "ModIOMPG.brn" I couldn't find it anywere. Thanks for pointing that out.
« Reply #7 on: April 09, 2016, 03:31:11 AM »
buenos dias
donde puedo buscar un manual de brains
  •  9,195 9,195
« Reply #8 on: April 09, 2016, 04:41:10 AM »
buenos dias
http://www.machsupport.com/videos/
« Reply #9 on: April 09, 2016, 05:07:04 AM »
es posible algun fichero en pdf para verlo mejor porque mi ingles es mejor en papel
