Hello Guest it is April 16, 2024, 12:40:47 PM
Author Topic: Mach error UNABLE TO LOAD..FTDI USB DRIVER ftd2xx.dll  (Read 3956 times)
« on: December 22, 2014, 05:43:41 PM »
Hoping to get a solution to a Mach3 error on start up:
Smoothstepper v17fc: "unable to load the FTDI USB driver ftd2xx.dll" followed by a 9991 triggered error and forced close down.
Is this a Windows 8 compatability problem? Note, I had a forced Windows Op update on my laptop (been putting it off and off but was forced in time to accept an upgrade. I have had SS problems with Win 8 previously.
Re: Mach error UNABLE TO LOAD..FTDI USB DRIVER ftd2xx.dll
« Reply #1 on: December 28, 2014, 01:32:18 PM »
Best check with Greg but it could be the driver is needing updated for W8.
« Reply #2 on: January 05, 2023, 10:09:25 AM »
Did you find a solution to this issue? I'm having the exact same problem.
« Reply #3 on: January 06, 2023, 05:15:14 PM »
This post is thirteen years old.
USB connected SmoothSteppers, USS, are obsolete, that is to say they are no longer being manufactured, in favour of the
Ethernet connected SmoothStepper, ESS.
You will find support for both the USS and ESS at the Warp9TD Forum.
https://warp9td.com/index.php/kunena/index
