In the Newfangled Mach 3 Wizard, when milling a circle or rectangle cutout, there is the option to cut inside or outside the shape and to either use a plunge cut or a ramp cut for each z step specified - moving to the depth and then cutting the circle/rectangle; and ramping downward while cutting the circle/rectangle at a rate of one Z Step per pass of the cutout respectively.
So far in the Newfangled Mill Wizard, with milling circles and rectangles, there is the option to cut inside, outside, or groove (which is a nice addition) and with circles there is the option for either a plunge or ramp cut, but only the ramp angled plunge option for rectangles.
I'm looking for the option to spiral cut downward when cutting rectangles, so that if I do not want to cut extra material while the tool is spiraling to the correct depth inside/outside the rectangle, I do not need to manually calculate the toolpath and use the groove option.
