Hello Guest it is April 25, 2024, 06:58:08 PM
Author Topic: Some sort of communications issue Mach <--> ESS <--> PMDX-126  (Read 2589 times)
« on: December 16, 2014, 02:05:58 PM »
Hey everyone,
Hoping you can help me with this.
I am having a hard time getting signals through the Ethernet Smoothstepper to Mach3.  This is a new build.
As far as I can tell, Mach talks to the ESS just fine.  I have gone through the ESS troubleshooting guide and have seen the ESS and the PC sending packets back and forth.
But when I change the status of any of the inputs, there is no reflection of that change in Mach.  The inputs are wired correctly - I can see the change in state via the status LED's on the '126 (both the E-Stop and the limit switches)   But either those signals are not making it to the ESS - or the ESS isnt correctly sending those signals to mach..
When Mach3 starts and I hit the reset button, I get the error "limit switch triggered"   The ESS status page shows pins 10,11,12,13 all unchecked - but that does not change when I manually toggle any of the limit switches or hit / reset the Estop.
So something isnt talking to something.
Any ideas?
Your help is appreciated!
