Hello Guest it is April 26, 2024, 05:33:48 PM
Author Topic: BobCAD, Mach3, Plasma cutting  (Read 14503 times)
Re: BobCAD, Mach3, Plasma cutting
« Reply #20 on: October 05, 2015, 05:38:26 AM »
Can anyone recommend any CAM for plasma cutting? Preferably free
Free I don't know of.
A friend is using Lazycam ( you need the pro version for Plasma) and the gode generated is good based on the required plasma inputs. You would need to set and use the plasma parameters in Options and need a workable script for the M code used.
FWIW,
