Hello Guest it is April 18, 2024, 01:00:51 PM
Author Topic: How set and reset output port in a script m1s?  (Read 4067 times)
« on: December 05, 2014, 11:40:30 AM »
Hello
I have an Arduino with a Modbus Software. It work fine with Mach3 and Brain. But now i want to Set/Reset Ports and to Read/Set Analog Data with Script in Mach3.
Everything i tried did not work. Can you please halp me how the Syntax must be?
I use the Serieal Modbus Plugin for configuration .
best regards
Werner
