Hello Guest it is April 25, 2024, 06:18:35 AM
Author Topic: The "Mach4" 3D Laser Build  (Read 27265 times)
Re: The "Mach4" 3D Laser Build
« Reply #30 on: December 06, 2014, 03:14:57 PM »
Waiting on wheels and lots of soldering.  :-\
Offline dude1
  •  1,253 1,253
« Reply #31 on: December 06, 2014, 03:43:02 PM »
look nice and simple good work like the hight you have it at
looks like it could wobble a little bit but at a guess you wont know to you run it flat out
« Reply #32 on: December 21, 2014, 08:45:29 AM »
Wheels on and all put back together, so far so good.  8)
Setting up and Testing alignment with laser spot beam.
To help in registration a short stroke air cylinder comes up with mach4 output then goes back down before Co2 beam is turned on.
Y axis is set to 150inch per minute X is limited to 700.
Z table axis takes a little to get used to, as Z travel up is actually in the negative direction
Offline dude1
  •  1,253 1,253
« Reply #33 on: December 21, 2014, 02:20:54 PM »
ill take two please LOL
looking good
« Reply #34 on: December 21, 2014, 07:05:16 PM »
Hi Craig, that looks real nice.
"I love it when a plan comes together."
Were you able to get more of the normal connecting hardware for the extrusions ? If so, mind to send me the dealer info as I could use some myself .... since I let a bit too many of mine go.
Again ... VERY nice work.
Russ
« Reply #35 on: May 06, 2016, 11:41:03 AM »
Thought id update this thread with an image of my latest test burn
3" diameter .171" deep in Hard Maple
40watt (K40 laser tube and power supply)
« Last Edit: May 06, 2016, 11:43:09 AM by Ya-Nvr-No »
  •  9,199 9,199
« Reply #36 on: May 06, 2016, 11:53:54 AM »
Nice work Craig.
« Reply #37 on: May 16, 2016, 09:37:31 AM »
Thank You, nice to have a new toy, I'm having fun.
Few more varies burns, testing and finding limits
« Last Edit: May 16, 2016, 09:42:37 AM by Ya-Nvr-No »
« Reply #38 on: May 16, 2016, 09:40:11 AM »
file size limited per post
  •  9,199 9,199
« Reply #39 on: May 16, 2016, 11:47:15 AM »
Very nice indeed - the next step is real topographical maps ?
