Hello Guest it is April 18, 2024, 04:23:55 AM
Author Topic: The "Mach4" 3D Laser Build  (Read 27186 times)
« Reply #10 on: November 07, 2014, 07:03:34 PM »
NP, I didn't expect to see two control panels alike.
got the Y axis just about ready for the belts.
home switches are mounted.
« Last Edit: November 30, 2014, 09:56:20 AM by Ya-Nvr-No »
Offline dude1
  •  1,253 1,253
« Reply #11 on: November 07, 2014, 08:34:32 PM »
its different looking.
once I get my panel and everything fitted and working on my emco. still weeks away have other work I have to get done before xmas
I will build another small engraver It will be like a laser you buy but made from recycled parts I collect dead or unwanted printers so it will be belt drive it will only be x,y motorised with a hand adjustable Z  and a base that can move up and down.
its based around a plotter but a bit stronger
« Last Edit: November 30, 2014, 09:56:33 AM by Ya-Nvr-No »
« Reply #12 on: November 07, 2014, 10:53:37 PM »
Hi Craig,
 Looks like there will be plenty of rigidity in that "cube".
Do you think you will need any diagonal corner brackets ?
I put some of that stuff together by tapping the 4 holes in the end with 1/4-20 and it is solid as a rock !
I might get to the inventory later this weekend, going out of town Tue., so it might be after that.
Looks real nice !
Russ
« Last Edit: November 30, 2014, 09:56:44 AM by Ya-Nvr-No »
« Reply #13 on: November 07, 2014, 11:05:33 PM »
Thanks Russ
It does feel solid but the test will be in action and if the quick stop and go loosen the connections. Easy to add support if needed.
Its coming along nicely. Thanks again
« Last Edit: November 30, 2014, 09:56:54 AM by Ya-Nvr-No »
« Reply #14 on: November 11, 2014, 10:09:52 PM »
Couple of videos of the servos and the PMDX-422 in testing phase
Table Lift:
http://youtu.be/TxBKOSu0Mls
X Axis @1500 inches per minute:
http://youtu.be/L1ByGb-z8Jk
« Last Edit: November 30, 2014, 09:57:05 AM by Ya-Nvr-No »
« Reply #15 on: November 12, 2014, 12:38:34 AM »
Very nice! How did you get the RH and LH ball screws coupled? Soldered? It's so neat that I can't tell...
« Last Edit: November 30, 2014, 09:57:15 AM by Ya-Nvr-No »
« Reply #16 on: November 12, 2014, 06:24:42 AM »
Thanks but, that is a purchased item, comes with a 3 phase stepper motor that I replaced for better speed and lifting capacity.
http://www.lightobject.com/Motorized-power-Z-table-600x400-50lb-load-P902.aspx
Thou I'm not sure how id test for what the limit might now be.
Scissor lifting tables are not linear in there ability to lift weight or position.
the graph shows some rough plotted points I'd created.
I believe the higher up on the travel the more ability to lift heavier objects. But not sure how they rate weight limits.
Suppose I could research it, but screw it, too busy right now.  :D
So screw mapping has to be used and I will need a Motor_2_Map.dat file to be created. (but that function is not quite ready as of yet in mach4)
Id purchased a 40 watt CO2 unit from them a couple years ago and now tore it all apart for this upgrade.
If I keep it lean I should have about $3500 in the whole project including the original purchase.
Never liked the small work size or the lack of height control.
But learned about laser cheaply and now attempting to make it a functional unit.
« Last Edit: November 30, 2014, 09:57:30 AM by Ya-Nvr-No »
« Reply #17 on: November 12, 2014, 06:49:50 AM »
Cool. Didn't know there were such ready things..
« Last Edit: November 30, 2014, 09:57:45 AM by Ya-Nvr-No »
« Reply #18 on: November 13, 2014, 06:26:49 PM »
Mirrors are now mounted :) hope to get the tube mounted this weekend. Damn there is a lot of dinking around to get things done the older ya get.  ;D
All this aluminum material is from scrap blocks that have to be sawed and whittled down to suit. So it takes longer, but I cant see not finding a use for what someone else's throws out.
« Last Edit: November 30, 2014, 09:57:55 AM by Ya-Nvr-No »
  •  9,197 9,197
« Reply #19 on: November 14, 2014, 02:41:42 AM »
It's certainly looking good Craig and a wonderful piece of engineering.
« Last Edit: November 30, 2014, 09:58:07 AM by Ya-Nvr-No »
