Hello Guest it is April 23, 2024, 12:13:12 PM
Author Topic: Brain to solve negative SFRO  (Read 7699 times)
« on: November 13, 2014, 03:54:47 AM »
Hello,
I've used an encoder connected to a pokeys to change the Feed Override value and a button to reset it to 100%
But now I can set SFRO to 500% and over and set it to negative values like -100%
When it goes in negative feed nothing happens because the mill is still in hold position but it's not much nice to see.
How i can tell at Mach3 that the minumum SFRO is 0%?
May I use a brain to do it or there is a specific setting?
Someone can help me to write a brain? I'm not able to.
Re: Brain to solve negative SFRO
« Reply #1 on: November 28, 2014, 08:05:33 AM »
FOVR is limited in M3 to:  0.0 to 3.0 (0% to 300%), with 100% being actually what you commanded.
it will NOT take a negative number. Nor will it allow you to go over 300%.
