Hello Guest it is March 28, 2024, 09:37:41 PM
Author Topic: ST-V2 5 axis breakout board  (Read 41508 times)
Re: ST-V2 5 axis breakout board
« Reply #10 on: February 18, 2016, 10:34:32 AM »
Hi 9fingerscnc,
I am newby with cnc and i also bought from STEPPERONLINE the same breakout st-2 + 3 axis nema 24 kit. You said everything was working except limit switches and e-stop. How did you wired your board? Did you follow the "Typical connection" of "comon anod(+) connection" between this board and motor drivers? (M542T). I mean did you joint in only one wire the (Pulse+) + (Dir+) + (Ena+)  from driver to 5v conector at board? And each (-) from the same to each conector at ST-2 board?
I am dealing some problems with connections. I follow the user manual recomendation of common positives. But i also saw at youtube people conecting with common negative wires. So, i am not sure what to do becasue it seems no one or other is working. But i am still trying some solutions.  Could you let me know how you did yours?
And about your issue? after this time is already fixed? how you did that?
« Reply #11 on: February 19, 2016, 11:59:10 AM »
Hello hersche
Do you mean that you have to supply a voltage superior as 5 v ?
THANKS
carmelo
« Reply #12 on: February 19, 2016, 02:13:17 PM »
Hi Carmelo,
  Yes, you must connect 12 to 24 VDC to the terminals indicated as that is required to operate the indicated inputs.
5V will not work.
Russ
« Reply #13 on: February 27, 2016, 05:36:02 AM »
Hi Russ.
Thank you very much for the answer. I'm know more confident and not affraid to burn something!
Regards
Carmelo
« Reply #14 on: March 27, 2017, 10:56:13 AM »
hello all, Tweetie, how are you my friend?  I am having the same problem.  The E-Stop just does not appear to work as it is supposed too.  I too have tried all of the settings, including connecting to P11 and changing the settings on the inputs,  but no joy.  If anyone has any ideas, please let me know, I am totally
 out of ideas.
Larry
  •  9,196 9,196
« Reply #15 on: March 28, 2017, 01:42:18 AM »
Hi Larry,
Nice to hear from you again.
There are disadvantages with that particular board...
1) It needs 12-24 volts in order for the EStop (or any other inputs) to work.
2) The EStop switch needs to have 'normally open' contacts (most are 'normally closed' contact).
Perhaps a different breakout board would be the best option ??
« Reply #16 on: May 28, 2017, 10:42:41 PM »
    Can anyone tell me what chips are those arrowed in Red? is it related to opto isolator chips?
[/URL]
thanks,
« Reply #17 on: May 28, 2017, 11:18:32 PM »
found it, 74HC2450.
