Hello Guest it is April 27, 2024, 12:52:29 AM
Author Topic: macros ignored  (Read 1641 times)
macros ignored
« on: November 06, 2014, 04:25:48 PM »
I had the mach3 configured so, when I activate an output from VB editor, it began to flash in red, opposite to for instance, the limit switches who are reflected as a stable green.
Then something happened, and Mach3 doesn't do anything with outputs.
I look for the solution in several ways, and found in the xml an option "Ignore macros" with a "1" set
1. Is there somewhere in Mach 3 configuration where I can change this?
could be it a problem of trying things with M6?
2. The led in diagnostics flash in red instead of simply be stable.  Do it mean the signal is flashing or something?
Thank you
