Hello
Guest
it is
April 24, 2024, 08:48:01 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
newbie....bitmap, jpg to Gcode?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: newbie....bitmap, jpg to Gcode? (Read 4783 times)
gldfshrdr
40
on:
November 04, 2014, 12:17:52 PM »
Reading in the manual tells me I can convert bitmaps or jpgs to Gcode. Problem is, the instructions don't match the available file menu in Mach3 2.0 . What am I missing?
I just got my CNC built and am looking for an easy way to get started carving. I have "Solvspace" as my CAD software. Solvspace does generate Gcode but it's very complicated for the type of simple things I want to do intially.
Thanks.....gldfshrdr
Logged
Tweakie.CNC
9,199
Super Kitty
Re: newbie....bitmap, jpg to Gcode?
Reply #1 on:
November 05, 2014, 03:30:21 AM »
Hi GFR,
What exactly is it that you wish to carve ?? (V-Carving, 3D relief, outlines ??).
Perhaps an example of you intended .bmp or .jpg may be of help here.
Logged
gldfshrdr
40
Reply #2 on:
November 05, 2014, 10:34:48 AM »
Simple V-carving of outlines to start. The wife wants custom Christmas decor. I'm starting real slow. I also put up a picture of my "see through" machine. I'm not sure I can do more than foam with it but I have cut MDF using the wizards and found a wobble in the Z axis that I corrected.
Thanks.......gldfshrdr
Logged
Tweakie.CNC
9,199
Super Kitty
Reply #3 on:
November 05, 2014, 11:08:18 AM »
Take a look at F-Engrave
http://www.scorchworks.com/Fengrave/fengrave.html
It's free, easy to use and makes a good job of V-Carving.
Logged
gldfshrdr
40
Reply #4 on:
November 05, 2014, 04:24:45 PM »
Thanks! I'll try it when I get home tonight.
thanks..........gldfshrdr
Logged
gldfshrdr
40
Reply #5 on:
November 05, 2014, 11:05:55 PM »
As far as I can tell, it works great! Thank you Tweakie! Now lets see what else it will do.
Thanks..........gldfshrdr
Logged
gldfshrdr
40
Reply #6 on:
November 06, 2014, 08:03:01 AM »
Thanks again!
Logged
Tweakie.CNC
9,199
Super Kitty
Reply #7 on:
November 06, 2014, 08:11:12 AM »
Excellent
Logged
Print
Pages:
1
Go Up
« previous
next »
