Hello Keith:
I played around with your problem, making an island .5 OD, and a circular cut-out 3.0 inch diameter, using a 1/4 end mill. I got the direction of the cutter wrong in my first tries, but it worked. I edited out the necessary lines of the Circular cut-out and both routines had the same depth. With the NFS Wizards, you can quickly see what is going on, and go back and edit the input file, and run it again. We're talking minutes to de-bug and do a virtual "run" of a strange program combo.
One of the nice features Ron built into many of the wizards is the variable to change the ramp into the work. You can make the ramp a small angular number, and the tool will spiral into the final depth, or plunge straight down if that suits the situation.
I have been using the Newfangled Wizards for a while now, and they are well worth the price. I use them nearly every day, for all manner of quick tasks.
Considering how much money I have invested in machine tools, CNC machines, tool holders, collets, rotary tables, motors, amplifiers, and various software, over the years; the Newfangled Wizards was the best $50.00 I ever spent.
You might give the CAD program "Draftsight" a look. It is produced by the parent company of Solid Works, and is free. All they ask is for you to register your name and email with them, and it is good for a year. It has a huge database of videos available, and is their effort to get people into Solid Works. It is an absolutely 100% professional level program, and is used world wide.
I use CamBam to machine the DXF files produced by Draftsight, and find them to be a very powerful combination. I bought CamBam and Cut Viewer together, and can see a virtual image of my machining program in real time, before I cut the actual material.
If I had to do a machine job similar to your standing island in a circular cut-out, I would draw it in Draftsight, output the DXF to CamBam, and watch the virtual machine process in Cut Viewer.
John
