Hello Guest it is September 10, 2026, 08:51:10 AM
Author Topic: GetVar(2002)  (Read 25756 times)
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: GetVar(2002)
« Reply #10 on: October 22, 2014, 06:30:18 AM »
post your macro
Offline amnon
  •  40 40
Re: GetVar(2002)
« Reply #11 on: October 22, 2014, 11:13:03 AM »
Code: [Select]
code "g90"
ChX = GetUserDRO( 1200 )
ChY = GetUserDRO( 1201 )
ChZ = GetUserDRO( 1202 )
Feed = GetDRO(18)
Code "G53 G00 Z-0.1" 'Move the tool all the way up
Code "G53 G00 X" & ChX & "Y" & ChY 'Move to the probe position
While IsMoving()
Wend
Code "G31 Z" & Z-100 & "f100" 'Z move down untill hit
While IsMoving()
Wend
ZposOld = GetVar(2002) 'Get the Position that the Porbe hit at
Code "G53 G00 Z-0.1"'Z move all way up
While IsMoving()
Wend
MsgBox ("Insert the new tool")
MsgBox ("Ok to finish tool change")
While IsMoving()
Wend
While IsMoving()
Wend
ZposNew = GetVar(2002) 'Get the Position that the Porbe hit at
Offs = ZposOld - ZposNew
Call setdro (2,Offs)   'Set the value of the DRO to the value that is in "Offs"
Code "G53 G00 Z-0.1"   'or hoever high you want to go to get up safely off the probe
MsgBox ("Ok to return to program")
Code "G00 x0 y0"
My intention is to understand step by step what is going on in each line, and make my own macro.
I change tools manually - Kress, and my tool height measurement is in the same location, so I have to measure each tool twice to calculate difference.
Maybe there is a easier way to do this?
Respect
Amnon
Offline stirling
  •  2,188 2,188
  • UK
Re: GetVar(2002)
« Reply #12 on: October 22, 2014, 01:50:24 PM »
your original post asked about MsgBox ZProbePos always printing 0
Not only is there no call to MsgBox in this code there is also no variable called ZProbePos
