Hello Guest it is April 24, 2024, 08:09:03 PM
Author Topic: Run a custom task  (Read 3423 times)
Run a custom task
« on: September 17, 2014, 05:00:20 PM »
Hello, I'm new to programming for the Mach3.
I'm wondering if there is a solution to intercept the g-code line executed and block the execution process from a plugin?
The loaded g-code already contains custom code, i want to intercept the custom code, block the machine execution, run a custom task and resume the execution of the machine.
Is this scenario possible from a plugin?
Thanks.
Re: Run a custom task
« Reply #1 on: October 27, 2014, 08:52:00 AM »
>>Yes you can.
>>Yes it is, but......  You could also do this using the
>>MacroPump and/or Brains....
>>Macros/Brains are much simpler to do than a plugin...
>>Look at the Mach Specific VB calls to write your own
>>macropump, and/or macros that it
>>fires off, or Brain functions that it would activate...
Scott
