Hello Guest it is April 18, 2024, 10:47:20 AM
Author Topic: C10 and Mach3 setup, motors not moving  (Read 5609 times)
Offline AVRnj
  •  52 52
« on: August 15, 2014, 08:16:02 AM »
I am wondering if anyone can help me out.
I just setup a C10 and kellig digital drivers.
My C10 board has power, my digital drivers have the green power light on, so they are getting power.
I followed the keeling wiring diagram, and I have no power at all to the motors. I have another CNC machine (Tormach) and I have verified that the parallel port works fine in EPP mode on my Tormach, and it can drive the motors.
I am assuming it to be a setting in Mach3 issue, but I am not sure. I have tried with the charge pump enabled and disabled, no luck.
I have verified I have the jumper set to output for pin 2-9, I have a jumper between 5V in and the en pin.
The only other thing I can think of is if the C10 pins 2-9 don't relate to pins 2-9 on the parallel port?
Any suggestions for me?
Re: C10 and Mach3 setup, motors not moving
« Reply #1 on: October 21, 2014, 12:45:55 AM »
I have been using the C10 bob on my machine for a couple of years with Mach3. So it will work. Did you assign the proper pin out to the 2-9 pins in the pins and ports section of Mach?
Steve
I have this ultimate set of tools I can fix it.
