I am about to use my first Hicon Controller. I have always used the Ethernet Smooth Stepper. I've only used the Charge Pump 1 time on a machine and it worked very well. On this new VMC we are retrofitting, I would like to have a charge pump for my relay outputs.
Here is why.... We use a Physical Maintained switch to cut the common power to the relays, when Mach gets closed for any reason, it turns all of the outputs on.
If I shut down Mach with the HiCON, will all of the outputs turn on?
