Hello Guest it is April 24, 2024, 08:48:59 AM
Author Topic: contour cut out with depth  (Read 1700 times)
« on: July 19, 2014, 11:18:50 PM »
So I am doing a contour cut out of a object.  It has a curve to it but it is the same thickness.
I don't have to do multiple passes just one outline but the height of the outline changes.
I have been doing it for some time now but the x and y slow down to adjust the height of the blade.
I have adjusted the z height manually but would like to find a way to get the blade to go up at the right rate so that the x and y don't slow down.
Any suggestions would be great
