Hello Guest it is March 29, 2024, 02:36:57 AM
Author Topic: Tangential control  (Read 2376 times)
Tangential control
« on: July 02, 2014, 10:45:26 AM »
Hello,
testing a sample on using tangential control with Mach 3, I found that this control works fine with GCode G1 but not with GCode G2/G3. Is a program known that converts GCode G2/G3 to small G1 segments or alternatively a description with the mathematic context to write an own program ?
Thanks, Nobima
  •  9,196 9,196
Re: Tangential control
« Reply #1 on: July 02, 2014, 11:27:22 AM »
Just in general but most CAD / CAM programs have optional post processors to create either arcs or arc tangent curves in the toolpath.
If it's any help I have found that with arc generated circles, creating a lead-in with the same radius as the circle solves the problem as the cutter rotates to the correct direction before entering the work.
« Reply #2 on: July 02, 2014, 11:54:54 AM »
I am working with RhinoCAM, can you tell me the name of such a post-processor ?
Nobima
  •  9,196 9,196
« Reply #3 on: July 02, 2014, 11:58:28 AM »
Sorry, I don't use RhinoCAM so can't help on that one. Perhaps if you contact MecSoft they will be able to advise.
