Hello
Guest
it is
May 01, 2024, 06:11:22 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
ANDing motor index pulse and a second switch to detect home position
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: ANDing motor index pulse and a second switch to detect home position (Read 2974 times)
drogge
8
on:
July 01, 2014, 11:57:59 PM »
Is it possible in Mach3 to "AND" two signals together to detect home position. My lathe has a proximity switch on the leadscrew pulley that pulses every 5mm and I'd like to add a second switch as something like a limit switch. I'd like Mach to detect home position when both of these switches are triggered. Can this be done in Mach or would it have to be some in hardware?
Thanks, Drew
Logged
Peter Homann
513
Re: ANDing motor index pulse and a second switch to detect home position
Reply #1 on:
July 02, 2014, 12:51:53 AM »
Hi Drew,
Yeah sure. Connect the two switches in series as shown here;
http://www.accentsensors.com/help2.aspx
Assumes that the new switch will also be a proximity switch.
Cheers,
Peter
Logged
Homann Designs
http://www.homanndesigns.com
drogge
8
Reply #2 on:
July 02, 2014, 03:12:07 AM »
Thanks Peter.
From cruzing Amazon I see that switches can come in NO or NC configurations. My current switch is 3-wire but I don't know if it's NO or NC. In the 3-wire series example in the PDF are the switches NO?
Drew
Logged
Peter Homann
513
Reply #3 on:
July 02, 2014, 05:51:54 AM »
Hi Drew,
Yes, they are NO. If you have NC switches, put them in parallel to achieve the same result.
Cheers,
Peter
Logged
Homann Designs
drogge
8
Reply #4 on:
July 02, 2014, 10:35:03 AM »
Thanks again :-)
One final question. It looks like the majority of proximity switches are listed as taking between 6 and ~30 volts, will they run off of 5V? That's the voltage that's going to my current switch and I'm wondering if it's something special.
Drew
Logged
Peter Homann
513
Reply #5 on:
July 02, 2014, 11:04:21 AM »
I don't know but I would think not as it is outside their specifications.
There are 5V proximity sensors though.
Cheers,
Peter
Logged
Homann Designs
Print
Pages:
1
Go Up
« previous
next »
