Hello Guest it is April 27, 2024, 12:43:11 AM
Author Topic: Screens now display at wrong height  (Read 4372 times)
« on: June 16, 2014, 02:26:39 AM »
I've downloaded a few screensets and now this happened. The picture shows that the Mach3 screen on the left is squashed in height but the width is ok. I've pulled up the bitmap in a viewer and that shows it ok on the right.
I have no idea why this has happened, I've downloaded other screen sets and they are all squashed now so it looks like a setting in Mach3 that's changed.
I wondered if it was something to do with a compatibility mode, or if there was a control inside Mach3 config that might be responsible but I can't find anything.
Does anyone know how I can get this to display at the correct resolution?
It only affects Mach3, all of the other programs I'm running look fine and the screen hasn't changed. It's not a system problem, it's a Mach3 one.
Offline Greolt
  •  956 956
Re: Screens now display at wrong height
« Reply #1 on: June 16, 2014, 03:13:03 AM »
Go to "General Config" and toggle "Auto Screen Enlarge"
« Reply #2 on: June 16, 2014, 03:16:44 AM »
Thanks for that, it now seems to be right. What I don't understand is how this came to be changed? I haven't changed it so I have no idea what did that.
Anyway, it seems right now so all is well.
