Like the title states, I'm struggling to get Copycat to work correctly.
First off I had an issue with my video pluggin that I intended to use with CC. Thanks to Klaus that is all sorted now.
I then downloaded the CC manual from the "Members docs" section on the forum. I read through the manual and played around in the default program and was sure that I would be able to use CC for what I needed, so I purchased an Addons licence.
I then found out that I still had the old version of CC installed, so I did a search and downloaded V1.1 and have that up and running with lic.
Now the problem is that I can't seem to get CC to function correctly.
I can set all the Feeds, Safe Z and Holes specs in their respective places. I can jog around using my camera and generate code that will cut a profile shape etc.
My problem arrises when I jog to the centre of a hole I want to cut.
The program requires a rapid or feed move to the center of the hole, that's ok. Then I tell it to "Cut Hole" and I get a popup window stating that the "Tool diameter must be larger than zero".
I have the tool diameter of 2.5 entered in the screen box, but when I type 2.5 in the popup window it rejects it. After much frustration and trial and error, I have found that it will only let me enter a figure between .1 and 2, nothing higher. This is regardless of how big I make the tool diameter in the onscreen box.
If I let it accept a figure of say 1, it posts up code for the hole cut operation, but I get this HUGE circle appear in the toolpath screen and it doesn't match the position or size of the required hole.
I have tried letting the machine cut the complete code. The profile with rapids and feed commands works perfectly, then it tries to cut the huge circle.
I have tried finding out why it does this but have drawn a blank. At first I thought it was a mm to inch thing, but my native units are in mm's and CC doesn't have anywhere to change that. I have created various tools in Mach3, but that doesn't seem to alter anything.
The other frustrating thing is that it overwrites the file and I have now lost the original file that I made.
Is there a way of adding to an existing CC file that has been created earlier? This would help so I don't have to go back and generate the profile section of my code.
I'm at my wits end with CC. Can anybody help me out?
