Hello Guest it is April 25, 2024, 04:44:11 AM
Author Topic: #var (Pound Var) parameters list docs..  (Read 14932 times)
Re: #var (Pound Var) parameters list docs..
« Reply #10 on: October 10, 2017, 12:36:33 PM »
In the RegFile plugin dialog, I opened #Variables, and manually set range #'s from the beginning til up in the 10,000's, looking for numbers relevant to what I was doing. I just happened across those two very familiar looking numbers pi and eulers in the process.
« Reply #11 on: October 22, 2018, 04:57:18 AM »
Here is a document that describes parameters for Mach 3. Not sure how much you can trust it however as I'm not sure which version it applies to. Hopefully someone can attest as to which version this is likely related to?
