Hello
Guest
it is
April 23, 2024, 03:24:58 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach3 cant reach desired position .00x
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 cant reach desired position .00x (Read 2402 times)
writerson
15
on:
May 16, 2014, 04:51:19 AM »
I have a rotary axis as x. normally i use steps per unit as 200 and velocity as 120. I have calculated a full rotation on x axis exact value of x12.6 and my 90 degree rotation is x3.15,
On another machine i was able to make a different reduction.
I made
Steps per: 195.4 and velocity: 36
Then i calculated an absolute rotation as X6.407,
after that when i try to send x axis to 6.407 i saw that is going somewhere else like x6.38,
I tried to change values like making steps per:1.954 and velocity:3600
In this calculation my full rotation was x640.7
i can get x640.7 on full rotation but my 90 degree rotation was x160.175 and i could'nt get exact value. it went x160.08 and measurements were wrong on table.
Any suggestions for this situation ?
Logged
Re: Mach3 cant reach desired position .00x
Reply #1 on:
May 16, 2014, 07:28:42 AM »
Rotary axis is A,B,C about the associated X,Y,Z axis.
A rotary axis can be linear or degrees.
You need required axis resolution for positional accuracy.
Not sure what your trying to accomplish by setting the rotary axis to X.
Logged
writerson
15
Reply #2 on:
May 16, 2014, 07:31:16 AM »
It seemed easier to me set it as a linear axis and measure.. how can i set it as a rotary "A" and tune it to 360 degrees ?
Logged
Fastest1
920
Houston, TX
Reply #3 on:
May 16, 2014, 08:49:11 AM »
On the general config page, check A axis is angular.
In the motor tuning section use a value of 200 x your micro stepping value to obtain the degrees (IIRC)
Logged
Print
Pages:
1
Go Up
« previous
next »
