Hello Guest it is April 25, 2024, 02:34:11 AM
Author Topic: Mach4 Printer Port Discussions  (Read 1249228 times)
Offline ART
  •  1,702 1,702
  • Tough as soggy paper.
Re: Mach4 Printer Port Discussions
« Reply #600 on: November 04, 2014, 08:01:34 AM »
Itll show up..  :)
Art
Offline ART
  •  1,702 1,702
« Reply #601 on: November 04, 2014, 08:04:37 AM »
In future guys, I think Ill just ensure Brian has versions appropriate for when they post new Mach4's, so then they can update their web link to an appropriate Darwin. That will keep you guys from having to search here, and if everything works as it should the web version will be up to date with the posted M4.
Thx
Art
  •  9,199 9,199
« Reply #602 on: November 04, 2014, 08:30:28 AM »
That's perhaps the best way to ensure compatible versions of both M4 and Darwin  ;)
Offline Racer
  •  16 16
« Reply #603 on: November 05, 2014, 10:58:32 AM »
I installed 2071 Mach4 and 2071 Darwin and still i get this in history.
Failed to license feature M4_DARWIN (mcDarwin)
Darwin License has failed with -33.
Do MDI
Do MDI
I tried renaming license file but still get the same thing.
Mach4 stops working after 10 min. or so.
Offline ART
  •  1,702 1,702
« Reply #604 on: November 05, 2014, 11:13:39 AM »
Hi Racer:
  The -33 is a "File not found" error, so your file is in the wrong spot, or the wrong name.
It should be in
C:\Mach4Hobby\Licenses\DarwinLic.dat
  The Mach4hobby may be Mach4 instead.. but the file should be named as above and placed in the licenses folder.
If it still gives a -33 error, then make sure m4 is up to date as well.
Art
Offline Racer
  •  16 16
« Reply #605 on: November 05, 2014, 11:51:30 AM »
Art
[/quote]
Renamed to C:\Mach4Hobby\Licenses\DarwinLic.dat
getting a -37 now
Darwin License has failed with -37.
Do MDI
Should I ask for a new License?
Jerry
Offline ART
  •  1,702 1,702
« Reply #606 on: November 05, 2014, 12:34:13 PM »
Jerry:
 Yes, error -37 means the ID is invalid so you need a replacement.
Art
« Reply #607 on: November 14, 2014, 02:56:17 AM »
Jerry:
Art
Great work Art, Thanks.
Does any one know What email address I should use to request a replacement Darwin license? The license I have is generating Error -37
  •  9,199 9,199
« Reply #608 on: November 14, 2014, 03:17:24 AM »
Hi Bezalel,
Perhaps best to just use the contact form here http://www.machsupport.com/contact-us/
« Reply #609 on: November 14, 2014, 03:24:28 AM »
Hi Tweakie,
The letter that came with the licenses only linked to the forum.
I'll give that url a shot.
Thanks.
