Hello Guest it is April 18, 2024, 08:25:17 PM
Author Topic: Mach4 Printer Port Discussions  (Read 1248028 times)
Offline Racer
  •  16 16
Re: Mach4 Printer Port Discussions
« Reply #450 on: August 22, 2014, 02:23:16 PM »
Art,
I have everything working on my 3D printer except no movement on Y axes.
X pins 7 and 1
Y pins 3 and 8 ( I tried switching them but same thing)
Z pins 4 and 5
A pins 17 and 16.
Moch 3 same computer works fine.
Any help?
Jerry
Offline peu
  •  23 23
« Reply #451 on: August 22, 2014, 02:51:28 PM »
Great, I have time this afternoon, will configure again everything and try the MPG and let you know.
Pablo:
 As of last nights version, yes, it is turned on. Set the MPG count and encoder number and it will send a message each time the increment is
equal or more than detent.
Art
Offline ART
  •  1,702 1,702
  • Tough as soggy paper.
« Reply #452 on: August 22, 2014, 02:58:17 PM »
Hi Jerry:
>>X pins 7 and 1
>>Mach 3 same computer works fine.
  If you switch the X and Y settings, does the Y then move when you try to move X? Does X move when you try to move Y?
Art
Offline Racer
  •  16 16
« Reply #453 on: August 22, 2014, 03:21:39 PM »
Hi Jerry:
>>X pins 7 and 1
Art
X Moves when I try to move Y
nothing moves when I try to move X
I switched the pin assignment only.
Offline ART
  •  1,702 1,702
« Reply #454 on: August 22, 2014, 03:30:58 PM »
Well, that proves its not Mach then. :)
 OK, so we need to know why pin 3 doesnt work ( Im assuming the STEP pin is pin 3? )
Well ignore the DIR pin as if it was bad the motor would still move, just in the wrong direction.
So search for any signal you may have turned in in other motors, or outputs that is set to pin3.
Its about the only thing that can stop you. The pin will not be set to step unless no other pin uses it.
  Pin3 is a bit in the 8 bit area of pins 2-9 , so theres nothing particularly special about it, so I cant see
anything other than 2 possibilites, the Y axis isnt working or the pin 3 signal is getting overwritten by an output
or other motor..
Any chance its that?
Art
Offline Racer
  •  16 16
« Reply #455 on: August 22, 2014, 03:38:58 PM »
or other motor..
Art
Pin 8 is step but I tried switching 3 and 8 no go.
All outputs are disabled.
All inputs are disabled.
I will keep playing with it.
Thanks Art
Offline ART
  •  1,702 1,702
« Reply #456 on: August 22, 2014, 03:47:11 PM »
Ahh, pin 8..
 Ill run a check just to be absolutley sure ..
Art
Offline Racer
  •  16 16
« Reply #457 on: August 22, 2014, 04:09:02 PM »
Ahh, pin 8..
Art
The Index number is real HI,  like 25018  when jogging motor #1
Motor #0 is 3221
Jerry
« Reply #458 on: August 22, 2014, 05:03:59 PM »
Art,
What would cause the a motor to move in darwin? It makes no difference whether the motor is enabled or not. I have had trouble with this since 1.145 although I never tested versions 1.15 or 1.16. Version 1.18 does this as well.
Ryan
Offline ART
  •  1,702 1,702
« Reply #459 on: August 22, 2014, 08:05:28 PM »
Jerry
The index doesnt matter, its just a count of how many steps it has moved since turn on..
Art
