'Bit of Word or Bit Packing/unpacking VB function for Modbus transfer
'Pick the "Start" OEM number for the UserLEDs you want to use,
'the function will use the start ULED number, plus the next 15 ULEDs a
'after that, so the 16 ULEDs in that range must not be used by anything else.
'For instance, if you pass 2001 (for ULED2001), to the function
'then the range of ULED 2001-2016 will be packed into a UDRO
'Of your choice, and you use that UDRO in your Brain to send out to
'Your PLC or whatever your using that can use BitOfWord registers.
'So you would also pass the OEM number of the DRO that you want
'to pack bits into. UnPacking works the same way, but in reverse, it unpacks
'a UserDRO into 16 (in series) Uleds..
'****This could also be done in wxLua as well for M4 just use the Lua equivs*****
' There is a screen Set (mill) for testing Bit packing and unpacking attached.
' it is called: "1024BitPackUnPackTest.set"
' Load this screen in your testing profile, when it loads goto the Diag. page
' Once there, you will see a large button toward the bottom corner of the toolpath
' window its label says "Go To Bit Pack/Unpack test page"
' There is a columb of ULEDs, you can turn them on off as you like
' they are listed as to what Bit in a 16 bit word they represent
' once you have picked them, push the "Pack this UDRO >>" button
' you will see it will populate the UDRO with the Decimal equiv.
' To go the other way, just put in a decimal number and press the
' button called "UnPack This UDRO <<" it will take the decimal value
' and populate the ULEDS in what would be their Bit Binary pattern
' Obviously this could be used to send and receive BitPacked UINTs to/from
' Brains across to/from a PLC or the like. To handle discreate I/O
' The functions are set up where you can pick your own ULED ranges,
' and UDROs
'Enjoy Scott Shafer!!
'the below scripts are in the Pack and UnPack buttons on the test screen
'///////////// Pack 16bit UINT Button, Script or Macro example //////////////////
Call Pack16BitWord(2001, 2000)'start at ULED 2001, and PackDro UDRO 2000
Function Pack16BitWord( ULedOEMstartNum, UDroForPacking ) As Integer
pUledCounter = 0
pDroValue = 0
For SixteenBit = 1 To 16
If(pUledCounter = 0) Then
If(GetUserLED(ULedOEMstartNum)) Then
pDroValue = pDroValue + 1
End If
End If
If(pUledCounter > 0) then
If(GetUserLED(ULedOEMstartNum + pUledCounter)) Then
pDroValue = pDroValue + (2^pUledCounter)
End If
End If
pUledCounter = pUledCounter + 1
Next SixteenBit
SetUserDRO(UDroForPacking, pDroValue)
End Function
'///////////// UnPack 16bit UINT Button, Script or Macro example //////////////////
Call UnPack16BitWord(2001, 2001)'start at ULED 2001, and PackDro UDRO 2001
Function UnPack16BitWord( ULedOEMstartNum, UDroForUnPacking ) As Integer
Dim BinaryArray(16) As Integer
WhileLoopCounter = 0
PackedDroValue = Int(GetUserDRO(UDroForUnPacking))
LeadingZeros = 0
While PackedDroValue >= 1
If(PackedDroValue Mod 2) Then
BinaryArray(WhileLoopCounter) = 1
Else
BinaryArray(WhileLoopCounter) = 0
End If
PackedDroValue = Int(PackedDroValue/2)
WhileLoopCounter = (WhileLoopCounter + 1)
Wend
For ArrayLoop = 0 To WhileLoopCounter
ArrayElementValue = BinaryArray(ArrayLoop)
SetUserLED((ULedOEMstartNum + ArrayLoop), ArrayElementValue)
Next ArrayLoop
LeadingZeros = (16 - WhileLoopCounter)
For RemainingNeedToZeroBits = 0 To LeadingZeros
SetUserLED((ULedOEMstartNum + WhileLoopCounter + RemainingNeedToZeroBits), 0)
Next RemainingNeedToZeroBits
End Function
