Hello Guest it is April 25, 2024, 10:59:41 AM
Author Topic: Mach 4 Bug Reports  (Read 499593 times)
Re: Mach 4 Bug Reports
« Reply #410 on: July 27, 2015, 11:20:18 PM »
V2580 there are glitches in teh elapsed timer. It does NOT reset correctly when it is suppose to.
« Reply #411 on: July 28, 2015, 01:18:05 AM »
Elapsed Timer problem here also, now starts counting as soon as i start Mach. By the time Mach is ready to use, the counter has already counted to 14 seconds. I think it appeared somewhere after version 2491.
« Reply #412 on: August 03, 2015, 07:43:46 AM »
Setting up MACH4 with a CSMIO/IP-S
Step/Dir servo powered spindle will not start unless spindle speed is changed via G-code 'S' command or override.
Some of the problem went away with build 2580. M4 works now, but M3 does not.
Based on the behavior, I would speculate that MACH4 only sends speed change info to the plug-in, because altering the speed started the drive.
It would seem that the speed data needs to be sent to the plug-in with any spindle start command. Why M4 works and M3 does not is a mystery.
M3 used alone does not start the spindle, however the following:
S5 M3
S1000
results in the spindle starting. Prior to Build 2580, the same workaround was needed with M4, but that seems t be working now.
« Reply #413 on: August 03, 2015, 11:53:01 AM »
Any future Mach4 bug reports should be submitted via a customer support request from our Contact Us page at the following link.
http://www.machsupport.com/contact-us/
