Hello Guest it is April 20, 2024, 12:37:47 PM
Author Topic: ESS / G540 / PMDX-126 WTF? About to give up  (Read 6772 times)
« on: April 28, 2014, 08:43:52 PM »
 Hello All
I am trying to integrate a Smooth Stepper / G540 / PMDX-126.  I understand the G540 is its own breakout board but I just want to use it as a motor driver.  I spoke with PMDX and they said it was possible to get this to work by (I think) hooking up the G540 to PMDX-126 (J19).  Smooth Stepper Port1 to PMDX Port 1 and Smooth Stepper Port 2 to  PMDX Port 2.  I am not sure what I am doing wrong but I just cannot get it to work.  I am pretty sure I am missing some things in ports and pins and maybe some other things in Parallel Port / Smooth Stepper settings.  Any advice / detailed instructions / Application Notes would be greatly appreciated. I have wasted well over 40 hours trying to figure this out when I am pretty sure there is a simple solution.  I am about to give up and call it a day, which I really don’t want to do.  Please advise
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: ESS / G540 / PMDX-126 WTF? About to give up
« Reply #1 on: May 01, 2014, 05:21:42 PM »
Yes, the G540 has its own BOB built in. Trying to feed it with another BOB is a recipe for disaster. Just run Port 1 from ESS to G540 and use Port 2 and Port 3 for the PMDX-126.
Happy machining , Jeff Birt
« Reply #2 on: March 13, 2016, 06:57:49 AM »
a quick question about the ess smooth stepper , I'm running a g540 as well and I have used all the pins for the plasme settings Torch up Torch down ect for the torch height control. my question is can I just buy another breakout board and plug the DB25 into say port 2 of the smooth stepper so that I can add homming and limit switches?
« Reply #3 on: March 13, 2016, 08:20:07 AM »
yes
« Reply #4 on: March 13, 2016, 02:36:26 PM »
nice
