Hello Guest it is April 25, 2024, 07:41:27 AM
Author Topic: How to Address Modbus Outputs if you have more than 20  (Read 22174 times)
Re: How to Address Modbus Outputs if you have more than 20
« Reply #20 on: September 12, 2014, 10:39:02 AM »
I have ,
I dont use mach with a laptop. Just curious.
Offline LGF
  •  37 37
  • can't sit still
« Reply #21 on: September 25, 2014, 05:22:47 AM »
on this question, I saw a tut vid where an additional port was said to be used and that one could with the 2nd port config them to all be inputs? Have a second port and might require this soon, with homing switches and limit switches (although all my limit switches are on 1 input pin)
When I die, will someone please dress up as the Grim Reaper and attend my funeral. No need to do or say anything, just attend and stand a short distance away? PLEASE???
« Reply #22 on: May 13, 2015, 04:18:53 PM »
Maybe I am missing something, but I am more than 50 ModBus addresses with Mach3. I have 40 Descrets, 16 Analogs, 200 Holding registers and 25 coils. the only problem I have is with 32 bit numbers.everything I want to display is 16 bit or a signed integer.
Jzee
