Hello
Guest
it is
April 19, 2024, 08:56:10 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Gcode MDI move to machine coords
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Gcode MDI move to machine coords (Read 4004 times)
Jimster
176
on:
April 16, 2014, 11:22:02 AM »
Guys,
I have a quick G code question for you, Can you move the machine to the machine coordinates and not the working coordintes with an MDI??
I'd like to make my machine go to x0,y0,z0 what command would I need to use?
Jim
Logged
ger21
6,295
Re: Gcode MDI move to machine coords
Reply #1 on:
April 16, 2014, 12:00:18 PM »
G53 G0 X0 Y0 Z0
Make sure the Z axis isn't going to hit anything.
Logged
Jimster
176
Reply #2 on:
April 16, 2014, 12:02:59 PM »
perfect, so simple even I can understand it, thanks Gerry
Logged
Overloaded
4,922
Reply #3 on:
April 16, 2014, 12:07:17 PM »
G30
I think does the same thing.
G28
Will go to the values set in the G28 Home Location boxes in the Home/Soft Limits dialog.
Russ
Logged
Jimster
176
Reply #4 on:
April 16, 2014, 12:09:01 PM »
ahh, I think it's G28 I need then
Logged
Overloaded
4,922
Reply #5 on:
April 16, 2014, 12:14:09 PM »
With G28, you can actually program the rout the axis' take to get home too.
Making sure everything clears.
Russ
Logged
Jimster
176
Reply #6 on:
April 16, 2014, 12:25:14 PM »
Thanks do I have to move x,y, then Z, or could I do?
G53 G0 Z0 X0 Y0
Logged
Print
Pages:
1
Go Up
« previous
next »
