Hello Guest it is June 16, 2026, 04:01:53 PM
Author Topic: Animatics Servo's  (Read 7618 times)
Animatics Servo's
« on: March 12, 2007, 10:49:40 PM »
Hello all!
First I wanted to say that I am sorry for not being on as much as I have in the past :( ... I have been working on the board from Delta Tau (Complex little sucker) and motors from Animatics. The Animatics are running Gcode and seem to be working! The DRO's are a little slow but other then that it is a running well! I am running all three motors over an RS232 network out of a USB Comport! The Comport is VERY slow compared to the PPort but I am getting the encoder data from the servo and if you get out of the following error you will trip an error in Mach3. Jogging is working VERY well! It is like jog on the PPort! As fas as I can press the key the motor is responding! I hope to have this plugin out in the next month or so and at that time I will be looking for people that would like to test.
So thank you and if you have any questions please feel free to ask
Brian
www.newfangledsolutions.com
www.machsupport.com
